Re: 1987 force 50 hp- no spark in both plugs.... new to this motor and need help
Get a spark tester.One that measures spark strength.
Weak spark could be a loose connection,loose ground,wire under the flywheel rubbed through and touching?
Shorted stator?
Go to outboard ignition . com or CDI Ignition both have test procedures for your motor.
