I posted a video how this motor in surging at wot. I placed in a tub so I could hold some rpms on this motor and watched the carbs with the airbox cover off and found a problem. The middle and the bottom carbs were really wet in the front and when you get the butterflys open i noticed fuel coming out in the circled area area in the pic. Now the fuel was coming out in big droplets and u could see it was bogging the motor out. I know the tube in goes into the high speed jet area in the bowl so i took the carbs off (I cleaned and rebuilt them last week) and check the jets all are clear and clean. The middle one is doing this although not as much and the top carb is not doing this at all. I checked the float and it was right. Need some advice here
