Re: Boat shop says I need a rebuild, not sure to beleive them.
Located in Dallas, TX.
Alarm buzzer sounds non stop when they key is on and engine is not running. Constant buzz with no stopping.
Problems right now are stiff throttle, timing linkage that has popped off twice, alarm buzzer, sluggish out of the hole.
17 Foot Ranger with 22 4 blade Cyclone prop that the trim has to be all the way down or it won't get to plane. Even at 1/4 up on the trim gauge won't plane.
I assume you're saying that the warning horn comes on as soon as you tun the key to the RUN position. If so, with it beeping, remove the TAN wire from the horn. If the horn continues to beep away, the horn is faulty.
If the horn suddenly stops beeping, then one of the sensors at the engine is shorted or the TAN wire is grounded somewhere. With the horn beeping, start disconnecting the TAN wire from the sensors... when the beeping stops, you've found the offending sensor.
The compression appears okay to me.
The timing linkage popping out problem... Usually the plastic retainer assemblies are worn and require replacing (both assemblies). But I have come across engines that have had a main bearing or flywheel problem, in which case the flywheel can be checked visually but the main bearings may be harder to close in on... try moving the flywheel back and forth (really lean on it) to check the play. A very small bit is normal but if you can move it say 1/6" of a inch or so... that would create a problem.
Stiff throttle: If it's still stiff when disconnected from the engine, then obviously the cable is okay... check on that.
Sluggish out of the hole: This could be the timer base sticking or somehow being forced to stay in the retard position rather then to be advanced before the throttle butterflies start to open.... could be a fouled carburetor or having the butterflies opening too soon in relation to the timing.
The butterflies should just start to open when the scribe mark on the metal cam is dead center of and touching the throttle cam roller.
I've tried to search thru the above, looking for mention of the proper spark to no avail... with the spark plugs removed, the spark should jump a 7/16" gap with a strong blue lightning like flame... a real SNAP! Does it? Note that using s/plugs to check the spark is a waste of time. The 7/16" gap is important. No tester?... build the following.
(Spark Tester - Home Made)
(J. Reeves)
You can use a medium size philips screwdriver inserted into the spark plug boot spring connector, then hold the screwdriver shank approximately 7/16" away from the block to check the spark or build the following:
A spark tester can be made with a piece of 1x4 or 1x6, drive a few finishing nails through it, then bend the pointed ends at a right angle. You can then adjust the gap by simply twisting the nail(s). Solder a spark plug wire to one which you can connect to the spark plug boots, and a ground wire of some kind to the other to connect to the powerhead somewhere. Use small alligator clips on the other end of the wires to connect to ground and to the spark plug connector that exists inside of the rubber plug boot.
Using the above, one could easily build a spark tester whereas they could connect 2, 4, 6, or 8 cylinders all at one time. The ground nail being straight up, the others being bent, aimed at the ground nail. A typical 4 cylinder tester follows:
..........X1..........X2
.................X..(grd)
..........X3..........X4
Let us know what you find.
