Re: Power tilt /trim ?
if you have galvanic corrosion then you may not be able to get it apart in order to install the orings. assuming that you can get it apart then you can rebuild the rams while they are on the boat for about $25, a good spanner wrench, and 2-4 hours of your time. check ebay for parts. mercury no longer sells everything that you need.
