brandonjohnson
- May 4, 2011
- 21
Hello,
BlackMax is a 150HP.
My starter stays "on" while the boat motor is on.
I turned off the motor and it is a buzzing sound, presumably the starter.
I had to disconnect the negative battery terminal to get it to stop. Then, bumping the negative terminal with the wire will attempt to start the motor even if the key is off.
Is this something replacing the key on control box may fix? Or does anyone know the wiring schema to tell me how to test what's wrong with key on control box?
THanks,
Boat motor repair rookie
THanks,
