i have this boat w. very low usage & very original everything.
original cap.rotor, wires, fuel filter. so i know that nothing has been done to it, is what I am getting at.
I have read posts about updated ase modules, etc, i believe this has none.
the shift microswitch( long arm) does not seem to work, i press it & the engine stays running smooth. the other switch does nothing either but from what i have read, this is the cancel out for the interrupt.
i try shifting the lower cable & it is smooth but stiff. is this correct or should I be able to slide this cable back & forth w/ease?
I just had the engine out to repair a water leak & fear I did not route the shift sleeve in its correct path/manner
& may have kinked the shift cable.
I never had any issue w/shifting prior. so I know it is something I did.
