Re: 1978 70hp johnson 70EL78C
I have a 1982 Evinrude 70hp and I have similar problems but I'll tell you what I do. First of all, don't prime the engine after that 20 minutes, rather just turn the key to crank the engine a couple times. And it won't start, that's ok. Then, after you crank it a couple of times push the key in to choke while starting the engine( like when starting it cold).
This usually starts it for me. .
Usually, the engine gets choked prematurely and ends up flooding the engine.
It has something to do with the fuel system, so a good idea would be to clean the fuel filter screen and the carbs.( a rag will do the job)
