rwall10597
- May 2, 2013
- 5
So I got lucky and got a 1984 Starcraft for free. I got it about two months ago but I waited till everything successfully transferred into my name before i spent any money. It took a little time because the guy i got it from was the son of the last registered owner, anyway, it all went through and i am rocking and rolling. The transom, stringers, floor etc... were all rotten. I did the transom a few weeks ago, then got the stringers epoxied in this week. I have the floor all cut and I set it in place to try out the motor. It has a 70hp Evinrude, also 1984. It hauls! When i first ran it in the tub I had it running really heavy on oil so it poured smoke, but with the right mix it was perfect. I went for a 5 minute trip with my son and clocked 33.8 on the GPS. I realized later the linkage wasn't quite right and the carbs were not opening even close to all the way, so I've likely got some more there, or at least that again loaded up with people and gear. I'm going to go out there now and cut the cross supports that go between the stringers, then hopefully get the floor epoxied in over the weekend.
I'm using 1/2 marine ply for the floor, and I've got outdoor carpet to put over it. I was thinking one generous layer of epoxy on the floor. My question to the masses, what should i do to the bottom of the floor? A layer of epoxy too? Paint? Nothing?
I got one gallon of west system, and i was hoping that would be enough. If i do the bottom of the floor too i bet i will have to buy more, then i will have enough for two coats on top too, ld like to make it on this $ wise, I'm probably down well below half. Please advise.
Also, i think based on the HIN its a 1984 st 140. Was there such a thing and how do i tell for sure?
