Re: I need to change the Trim lines on my volvo penta can someone walk me through It
I have just done this job.
My lines have been worn where they rubbed against the sides of the transom shield, whilst not leaking they were worn through the first layer of reinforcing. After 13 seasons of corrosion in salt water there was no way I could get the pipe fittings out from the little manifold. So I had to remove it with the lines in place.
The manual is very simplistic, with the engine in place you have no access to the inboard side of the manifold.
Make sure you have slack in the two inboard lines, remove the nut and washer on the manifold. try as I may the manifold would not budge.
I ended up threading a length of 4mm nylon line crisscrossed around the pipe nuts and then used a lump hammer connected to the nylon line to jerk the manifold out. Once free it will only come out 1/2 an inch until it needs to be turned to allow the internal hoses to pass through. With the external lines connected it cannot be turned enough. My only solution was to bend the port side stainless lines close to the manifold 90 degrees, then it was easy to pull the manifold out enough to remove the two internal lines.
In my case as I am replacing all the lines and the manifold bending the lines was not a problem. BTW the manifold is expensive!!!
