Bravo III Neutral
victoryinerie
I took my outdrive off to inspect bellows, bearing, etc and everything was ok...
I put everything back together and it seems like I don't have nuetral? When the engine starts it is in forward, I can put it in reverse but not nuetral?
Any advise?
Don S
Re: Bravo III Neutral
Your cable probably missed and pushed the linkage into forward. Pull the drive back off and check.
victoryinerie
If that were the case would I have reverse?? Going to check now to see if reverse works..
Hoosmatroos
No, i think you don't have reverse then. The cable missed and could not pull the linkage to the front to put the drive in reverse (or neutral)
