Good evening,
I just replaced the stator on my Johnson 1997 40hp engine today since it wasn't starting any more and the engine started with the first crank but then there was smoke coming from the stator. I shut the engine off and it kept on smoking until I disconnected the battery.
It seems like I connected the yellow wires at the right location however when I connect the 2 yellow wires it starts to sizzle and overheat. If I disconnect, one of the yellow wires it stops.
The other thing that I found interesting is that before I was able to shut my engine with the key but it didn't shut off this time. Really confused with this issue. If anyone can suggest anything since I'm out of ideas.
Thanks
Thanks
