Re: Boat trailer lights
Not seeing any pictures or knowing what type lights you have, any time you are not getting a light to work it is either a grounding issue or the 12 volts just isn't making it there. There are no other possibilities... You either have a ground missing or the voltage is not making it to the light. Take a volt meter and measure the voltage there to ground (the trailer frame or what ever is your ground) when you have someone press the brake pedal. Do the same for the turn signal wire too. If you do have voltage there, then it is a ground issue...
