Tempest plus to Trophy Plus
Phunahm
I purchased a 25 tempest plus for my 17' 150xr2 and I have no hole shot but top end is great!! I have a chance at a 25 Trophy plus will Run into the same problem with the hole shot with a 4 blade...... 65@5400 with the tempest plus
dan02gt
Re: Tempest plus to Trophy Plus
Have you played with the PVS exhaust venting plugs to help hole shot?
A 25P prop is a lot for a 150 to turn unless your hull is very lite so you may what to try a 23 or 24P Tempest. I suspect the Trophy will be as slow as the Tempest out of the hole.
Phunahm
Thanks yes all pugs are out....... it is a light hull but me alone in the boat is a 10 second count before it catches her breath and jumps to 3300 rpm
jestor68
The XR-2 likes to run at 5800-6000 rpm. You have too much pitch. A 22 pitch Laser II would be a better choice to improve hole shot and let that baby scream like it's supposed to. :)
The built versions run 6000-7000 rpm.
Phunahm
A 23p over revved and my 4 blade 24p ran 6000 plus.....
dan02gt
In that case I would recommend having a your 25P Tempest worked by a prop shop. I would recommend Mark at Mark's High Performance Propeller. Mark's High Performance Propeller, call him he'll know what to do with it. It may be as simple as adding a second set of PVS holes for a little more venting and maybe reducing the pitch a little.
jestor68
A 23 and 24 pitch WHAT? If you switch brands, your results are all over the place.
Since you don't mention what boat/ set up you're talking about, nobody can do anything but throw darts at the board.
