1998 Johnson 130. A lower carburetor is leaking gas when in the tilt up position, no leak in the down position even when running. It appears coming from the screw on the lower housing ahead of the high-speed jet. I?ve changed out the float and nozzle parts, I?ve doubled up on the ?o? ring seal at the screw, and I?ve looked for a visible crack in the housing, which looks OK.
The leak is pretty heavy but only when the motor is tilted up. It got me scratching my head.
