Re: 115HP evenrude tilt and trim leaking hydrolic fluid
seal kit including new upper seals for all rams. you will have to examine the parts diagrams to make sure that all upper seals are included. Some manufacturers sell upper seals separately and some even require you to buy a new cylinder cap (aka head).
you need to make sure that no water remains in your system even if this requires a full drain, flush, fill. If oil comes out, then water can go in. Trim systems depend upon precision tolerance ball bearings and steel compression springs for operation. Water will attack both of these and, in extreme cases, can even lead to non-repairable system failures.
as regards draining & filling. If you do drain & fill then the best way to fill is usually during assembly. You leave the manual release open (with engine safely and securely blocked up) and pour your DX3 fluid directly into cylinder before inserting piston. you push piston into place just past top threads and install cylinder head. This eliminates the air bubble under piston and and virtually eliminates the need for post assembly system bleed.
