Blake0912
- Oct 31, 2010
- 310
I have a 1992 40hp merc 4cyl on a 13ft whaler , I'm currently running the prop that was out it from the factory (12P). The boat does not have a tach so I'm just posting to see if someone else has a similar setup and what pitch prop you are using. I'm looking to get a better hole shot and more top end. What would yall think about using a 14P or a 15P? Also is it worth running a SS prop on a 40hp motor? I mostly run the boat in back bays/flats.
