osborne looney
- Aug 31, 2011
- 117
I have a 1975 merc 9.8 ser # 4084899 -- i have been through the carb two to three times now new diaphram kit in f-pump as well -- set and reset float many times as well -- motor will not run unless fuel is pouring out mouth of carb with full choke on - push choke in starves and dies -- crank seal under flywheel is good -- could a lower crank seal cause this problem ? i am starting to lose it on this motor please any help would be great thanks again I BOAT MEMBERS
