I have a 2005 Larson with a Faria multi gage (RPM, fuel level, volts) that has slowly failed over the last three years. Two years ago the fuel level gage failed high. Last year the rpm gage failed (stuck) at about 3,000 and this year the volt gage indicates about 12.5 volts with the engine running - checked the battery with engine running and its voltage is about 13.4 volts.
Anybody else have problems with this type multi gage? Am I doing something wrong - gages need maintenance like cleaning connectors? I live and use the boat on a fresh water lake. All the other gages work OK. I pulled the fuel sensor and the float was not stuck at the top.
Also I am unable to find a replacement - anybody know of one?
thank you
Jay
thank you
Jay
