I plan to buy old boat.
It has V8 GM 350 motor (about 3000h on it) and OMC 800 outdrive (1979). Motor clean, no oil under...
Start and run perfectly.
Everything was just fine during the test drive on the water.
But after 20 minutes run on moderate and high rpm I decreased speed and motor was stalled and even don't want to be started (starter work, no ignition).
Owner (he is mechanic) said that carburetor put too much gas to cylinders. Removed spark plugs, clean them and motor was started.
Funny thing, that it is repeatedly happened in next 20 minutes.
Owner said that it is just "spring problems": some cloudiness in carburetor collected during long winter. He promise to easily clean up carb and it will never happened in future.
I decide not to make decision now and going to visit him in a week because I am not sure that such motor behavior is not a symptom of serious engine problem.
What do you think? What to do to check it? I have no chance for another test drive.
