Re: 1977 Evinrude 55HP -> Bad compression on one cylinder
Before you spend any money on the carbs, look into the compression prob. Pull the cyl head and have a look at the gasket and the cyl's
Yeah? 13 % difference, is it really that crucial?
I am a bit reluctant to do that now, since I fear ending up breaking one of the bolts. It is spring in Norway now, and I dont want to end up waiting for parts when summer is here. But on the other hand, I would like to replace the thermostat. Hmm.
It got the engine up running today btw. It seems to lack some tune up in general. Next thing now is to check the gearcase oil for water and renew, boil the carbs in citric acid and get the ignition timing adjusted.
If there are no big surprises tomorrow with the gearcase oil, I guess I?ll just order some seafoam and hope for the best regarding the compression difference. At least for this summer. After all, its just an old outboard...
