brnschoneck
- Feb 22, 2013
- 337
Ok so I am preparing to check timing after cleaning carbs n points ...I found the manual states btdc being 2.00 i also saw it somewhere as 0.02 so im a little confused does anyone know what the number actuall is for sure when setting the max advance i beleive after tdc and setting dial indicator to O degrees ...thank you in advance just dotting my Is n crossing ts before i get started ...
