Hey guys a couple months back i bought a boat with 1985 johnson 150 outboard on it and have been fixing all the little things that were done wrong to it. now i am only a few steps away from having a great running motor. My problem currently is that when running at about 3/4 throttle or more my motor will suddenly bog down. i can let of the throttle all the way once or twice then hit it and it will pick up again. would an air leak at the block create this? also as i mentioned several things were done incorrectly on this motor, i has 2 premix vacuum pumps on the block. One pulls the fuel from the tank and the other pushes it into the carbs through the same setup of hoses that the VRO did. i would like to know what the part numbers of those pumps are supposed to be when correct. also i want to make sure that the hosing is ok the way it is. The only place there could now be an air leak on this boat would be either the plastic rod that runs to all the carbs or on the block itself. everything has been rebuilt and checked. Thanks alot for any help! its fishing season and schools almost out i wanna be on the water!
