I have a 1987 200hp Yamaha. The tilt trim quite working so I had the hydraulic motor rebuilt put it back on and still nothing. I took the wires and checked by leaving 1 on and grounding the other and it works that way but when you hook them back up the way thy are supposed to go all you here is something click. Not sure if it is a relay or if maybe something that is not grounded good Please any advice would be greatly appreciated. Thank you in advance.
