So the boat will not fire up today. Quickly figured out there was no spark. Grabbed a multimeter and tested the + and - on the coil, it is 0 while sitting and 12V while cranking, but ONLY if i touch the negative lead of my meter to the metal engine block, it appears that the (-) side does not have a path to ground. My first though was to make a new ground, then i realized it may be a safety feature to kill the engine. There are 2 wires from the (-) on the coil, both disappear into large harnesses/connectors so impossible to trace. Anyone know what would cause loss of ground to the coil?. I naturally think that any kind of kill switch/safety/esa fault would kill the (+) to the coil, but who knows?
its an 86 OMC 2.5
thanks
its an 86 OMC 2.5
thanks
