Hello, ok i bought my first boat. My outboard is stuck in the down position. I used the tilt trim, and i get a tap in the cylonoid. I tried manually jumping the cylonoid with the same result. Also i have no key for ignition. any ideas how to hot wire to see if motor runs. I could really use advice. Thank you. (Seahorse)
