Suzuki DT75 carb screw settings?
Choo Choo
Hi, after cleaning the carbs out can anyone help what the idle screws should be set at?
There seems to be conflicting views of between 1 1/4 and 1 3/4 turns. Is anyone 100% sure?
Thanks.
stylesabu
Master Chief Petty Officer
Re: Suzuki DT75 carb screw settings?
split there differance 1 1/2 turns and adjust as needed
Choo Choo
Thanks,
You were reading my mind if I didn't have a definitive answer. It's just over fueling at 1 turn so the next step is 1 1/2 and see..
Cheers
