jamesbirmingham
- Feb 4, 2011
- 16
I have a stratos with a 2000 Evinrude 200HP on it.. I changed the lower unit out and put the prop on and there is a large gap ( 5/16 to 1/2) between the prop and the lower unit housing.. It seems like my boat is cavitating on hole shot and I have to feather my throttle to get it to catch back up.. I believe that the exhaust is escaping though that gap between the prop and housing.. Read somewhere that there is suppose to be a exhaust seal in this gap??? It looks like the lower unit is threaded on the inside for something, could there be a seal that is suppose to be threaded in there??? Boat runs great after I'm on plane.. I thought at first the rubber went out in the prop so I had it redone by power tech in Shreveport so that's not the problem.. Any help would be appreciated.. I don't have the old lower unit so I don't have anything to compare it to that is real close by..
