I need some advice from someone that knows about aluminum structure and welding. I have determined without a doubt that I have some leaks in my pontoons behind the lifting strakes. When the lifting strakes were added the welding company skip welded the strakes about 2-3 inches long every 2-3 feet rather than welding them solid. I pressurized the toon to about 1 PSI and used a short piece of garden hose to listen with and I can hear air blowing in several places behind the strakes.
It?s easy to live life in the rear view mirror and say ?if I would have only ? then ?? But my situation at this point is there are pin holes either in the strake welds or in the joints between tube sections that are not accessible. I?m looking for input on what to do.
I?ve seen strakes on some new boats that are welded continuously down the entire strake making them sealed air tight. They could always put a drain plug in the rear. Is this long of a weld feasible? If so, we use about 1 psi of nitrogen flowing through copper while brazing refrigerant lines to reduce oxidation internally. The other end of the copper is open. Would this help keep the foam inside from burning?
Other ideas??
Other ideas??
