1984 50 hp Mercury Water in #1 Cylinder
R B
Engine lacks for power and I found water coming out of the #1 (top) cylinder plug. What should I look for before I pull the engine apart for repairs?
Bosunsmate
Re: 1984 50 hp Mercury Water in #1 Cylinder
Have you done a compression test?
Id start on the cylinder head water gasket and then if that doesnt fit it check the exhaust gasket/plates
R B
All 4 test at 120 psi. I have a repair manual but I didn't see anything about a cylinder head water gasket.
Bosunsmate
Maybe im looking at the wrong model, is yours 4cyl? Sometimes its called a watercover gasket
Is there a headgasket on this one instead?
emckelvy
If it's coming from the area where the cyl block water jacket cover seals around the spark plug holes, it's just a leaky gasket that can be replaced.
You do need to be careful when removing the 1/4-28 bolts as they have a tendency to seize in the block and snap off if too much force is used. Instead, use a heat followed by penetrating oil (as required). A propane or MAPP portable torch should have plenty of power for this job.
The gasket you need is Merc P/N 85487.
If you're in a pinch and have to get it out on the water, just clean around the leaking area and temporarily seal it with red hi-temp RTV sealer.
HTH...........ed
Chinewalker
Okay - subject says water IN cylinder and later you say water coming OUT of cylinder. Makes a big difference as to where you're findi g the water.
Faztbullet
Agree with Chinewalker...water in cylinder= exhaust cover problem or reed...outside = water jacket gasket
R B
I originally said water in cylinder as I believed water was being pushed out what looked like from the spark plug. Al this information is very helpful as I am noe believing it may just me the cover gasket. The next step should be to remove the water jacket cover to check the gasket.
No head gasket on this engine.
Bosunsmate
Yep most likely the water cover gasket. Have a look at your spark plug, is it similar in colour to the others?
R B
I installed new plugs a couple of weeks ago just because the boat is new to me. I pulled the water cover off and the gasket is definitely in need of replacement. Would the water getting out by the plug cause the motor to run poorly? Especially at wot?
Bosunsmate
Yep the plugs will short to ground via the water
R B
Not a bad job to replace the water cover gasket. I was so excited to think I would be finished and ready to go boating. Went to start the motor and it fired for a split second right away and then it just cranked and cranked and........... You probably get the picture by now. Looking for a fresh start tomorrow before I start throwing my tools!
Any help again would be appreciated. So far everyone has been very helpful and I thank you! I don't remember becoming a boat motor mechanic when I bought this but I must say that I have learned a lot!
