So I was having an overheat problem that I just fixed caused by the Raw water pump having two o-rings from an impeller change.
When I was diagnosing the overheat, I flushed my manifolds with fresh water to see if I had a blockage causing the overheat, there was water coming out the drive where it was supposed to be, but water was also exiting some where from the gimbal/pivot. I couldn't exactly tell due to the boat on a lift and I had to get in a canoe to get up underneath the boat.
Question, is water only supposed to exit through the exhaust port on the drive or is there another exit as well? There is no water coming into the bilge.
Thank you for the help.
