after putting my e110tlcca 1988 together with the carbs from a 100999s 1979 and the electrics from same 1979 motor , i got it to run but it doesnt start every time unless i mess with the carb linkage , and when it does run is verry erratic and it spits fuel out from the top carb, and spark plugs from cyl 1 and 4 are really black , 2 and 3 are wet. i bought a kit to rebuild the carbs , all i did i change that seal thats between the floater compartment and the upper part(i dunno is is more to it or not)i clean them really well with carb cleaner ..and it still spits fuel from the top one but it doesnt cycle, it turns over but thats it !!
