tidehunter
- Apr 27, 2013
- 6
Hi, New to this forum, hope someone can give me some advice.
2002 Mercury 150 V6 Outboard, Saltwater Carburetor. I need to replace the rigging tube. Can't quite figure out how to disconnect the throttle cables. Got the ends disconnected from the linkage easy enough. Seems like the two screws I need to remove to free them from from the part that holds them in place to the motor housing have solder where you would put the screwdriver tip. This indicates to me that I shouldn't touch them, but I need to remove them from this spot in order to feed them back through the tube. Can I remover these or is there another way? Should I melt the solder out and unscrew the screws? Thanks for your help.
