Was running fine last fall, treated the fuel, fogged each cylinder. Went to start now and it fires up ok but only runs for a second or two and then dies. It is so close to running, but just will not stay. Tested fuel pressure at test port and have 20 psi which meets spec. Plugs are new, gapped and indexed, they are getting wet with fuel. Crank position sensor correctly gap. No check engine light showing, all fuses checked good. HP fuel pump runs for the spec 10 seconds and turns off unless cranked. Fuel is being delivered so lift pump appears ok. Boat and engine fuel filters replaced, new gas. So far no joy. Any ideas? Thanks for any help!:joyous:
