Need Safe Distance
Thomv
Can someone chime in as to what is considered a safe distance that the front of my bow is to the back of my son's Expedition. I am in the process of moving my boat further forward on my trailer to give me more tongue weight.
BobGinCO
Re: Need Safe Distance
If it doesn't touch the expedition, you're good to go.
airdvr1227
Hard to imagine you could get too close.
smokeonthewater
if it gets under 6" you will need to pay CLOSE attention on uneven ground.....over a foot you're gtg short of running the Baha 1000 course.
We once put a bow pulpit through the back window of a suburban towing a 28'er through a small drainage ditch in my buddy's back yard heading to the 'engine pullin tree'..... He had towed a couple thousand miles on flat ground with no issue.
sublauxation
I have an Expedition too. The first time I adjusted my trailer to make it fit in the garage easier I couldn't open the lift gate in back. That sucked. I moved it back the extra couple inches an it's worth it for the convenience.
UncleWillie
That is the key dimension!;)
If you cant open the hatch; you're too close.
As long as none of the boat is in front of the ball, it won't hit anything in a sharp turn either. :joyous:
smokeonthewater
it's when the front tires of the tow rig go up a steep driveway and the rear ones drop down before going up into a gas station that you could find trouble
colbyt
Master Chief Petty Officer
I am a newbie at this trailer stuff so listen to others first. I consider the minimum safe distance to be that a 90 degree jack knife can't touch the tow vehicle. I know I am never going to turn a corner that is going to require more than that.
JB
Don't move the boat, move the axle. The boat must be positioned with support under the transom or hull damage may result.
Thomv
Right now my bunks are about 1 foot past my transom.
saumon
What JB said. Ends of the bunk should be flush with the transom so move the boat and winch post back, then the axle too until you got proper tongue weight.
That is true unless you have a trailer that is unappropriate (too long) for your boat, which happen more often than not.
UncleWillie
A HORIZONTAL Jack Knife where a rear fender gets crushed is one concern.
As other have stated; the other concern is VERTICAL Jackknife where the roof is crushed or the bow goes through the back window.
tazrig
^^^+1 As stated above the transom should be flush with the back of the bunks. Once you have got that done move the axles towards the rear of the trailer to add tongue weight and towards the front of the trailer to decrease tongue weight.
lrak
Unless you have a pontoon boat, classic Whaler, Carolina Skiff, John boat, catamaran, or something else with an almost square front. :)
spdracr39
Keep an eye on the winch handle its not on center and will hit in a turn if too close.
