ok this is my story so u can understand what exactly happen:
i had a ranger vip witha 90 hp that got stolen ,i bought a motor for spares a 110 evinrude , i took different things from it like the carbs , bolts , small stuff. after that boat got stolen in 2011 i bought another one with a 100 hp evinrude 100999s a 1979 which ran ok till a month ago when it threw a rod and apparently they dont work anymore if the do that! so in my wisdom i thought will be better if i take the electrical and the carbs from the 100 hp with the magnito and the stater and all the wires and transfer it to the 110 , i did all that I DO HAVE SPARK on all for (really bright) so i think i did ok by transferring the electrical stuff , i put back the carburetors and the part that has four chambers with things in it that have some kind a blades round at the tip on them, i hook it up to my fuel tank and i hot-wired it to start . it turns but doesnt start , i sprayed gas mix in the cylinders from where the spark[lugs go and tried again , i wanted to start but didnt turn over and it back fired, i took some starting fluid and sprayed into the carbs and same symptom , i do get alotta exhaust fumes and it back fires.
i do not have the lower unit attached yet . do you guys think by backfiring with no lower unit can damage anything?
hw do u exactly use the timing gun , what do u listen ot look for , the withe mark that is on my fly whell is at 28 , what is the timming for a 110hp 1988 evinrude e110tlcca .thx so much
