2005 5.0 GL-E. Just replaced engine oil, fuel filter, and lower drive oil. Started up and ran it on the lake for 15 minutes and did great. Stopped and restarted a couple of times fine. Put it on the boat lift, came back 4 hours later and it would start and run for about 1-2 seconds then die. Tried moving the throttle when it would start but no change. Thought maybe flooded so let it sit overnight and tried this morning with same results. It has never flooded and had this problem before. Suggestions on troubleshooting? I did look at the carb choke plate this morning before trying to start the engine and it was closed but figure a cold engine.
thank you.
thank you.
