I am new to iboats and this is my first post. I have already learned a lot from all the knowledge shared on here. I am about to start replacing the wood and carpet in my 1988 Lund Pro V 1700. I am ordering carpet samples today and I have the hardware picked out for latches, but I had a few questions regarding the reconstruction.
I was planning to carpet the plywood and then reinstall with rivets, but the floor is wider than 1 sheet of plywood, so how do I join plywood and maintain strength? Also, My side compartments are covered with a vinyl fabric, what do I need to replace this stuff with something that is durable? Is it naugahyde? I am unsure of using the same compartment hardware (door stops/catches), is there something better than the original?
I am sure I will have more questions as I go, I have only just started. I see there is a forum for a Pro V 1700 dlx restoration, so if thiker15 is still around, I would appreciate any advice/tips you could offer. Thanks in advance.
