boatmanbilly
- Apr 24, 2013
- 4
Have a 2003 SeaRay SunDeck 240 with a 5.0 L MPI, cool fuel 2, and bravo 3 outdrive.
The smartcraft alarm keeps going off "engine alarm". Checked the codes and got these:
119 Stear ckt low (Active code) - have no idea what this is.
130 Trim ckt voltage high. (Active Code). Thinking this is the drive mounted sending units (never been changed - gauge inoperative)
151 Fuel pump ckt (old code) - One day last week the fuel pump came on with the key on - engine off as normal to prime but the pump would not shut off. Turned off the key and it has not happened since. Thinking of replacing the fuel pump relay.
152 IAC output (old code) plan to clear this code and see if it comes back. If so replace the IAC?
Love this site and read all the time. This is my first post - hope someone can help!!
Thanks...
Thanks...
