CaptainTDawg
- Apr 22, 2013
- 12
Hey guys,
Im having a rough time with my used boat I bought. I cant get the damn thing to start!
I think maybe I fried something in the ignition system. The starter motor runs fine, the choke engages, but it seems I have no spark. It wont even hiccup or pop or backfire or nothing like that.
I tested if the spark plugs have spark by removing one of the spark plug wires and connecting it to a fresh spark plug outside the cylinder. I turned the key, and looked back at the spark plug for any blue spark. Did not see anything. The sun was shining on the plug end, so I shadowed the end to see a spark, and still I saw nothing. Maybe the spark is not easily seen in daylight? Is it invisible? I'm not sure if this is how you check if you have spark, so please let me know if I did it wrong.
Also, it appeared that the starter motor was stuck in the "start" position on the flywheel. I know the pinion gear is suppose to raise and lower during starting, but right now its stuck on the flywheel and will not lower. Could that be the problem? Maybe a sign of the true problem?
There seems to be another problem as well. I tested starting the engine in a 45 gallon storage tote with water. And when I tried starting, it would occasional leave some oily gas in the tote. Looked like it was coming out of the water intake for the engine cooling system. Fuel leak? Maybe its from excessive gas leaving the cylinders from trying to start for an hour (with breaks for the starter, of course). Not sure what the leak means or if its a serious problem
Please help! I'm trying to avoid paying a costly mechanic and trying to do it myself.
Thanks for any help!
TDawg
TDawg
