Symptoms: (1) Starts and runs perfectly up to 3,900 rpm. (2) At 3,900 rpm when throttle advanced, surges between 3,900 and 4,200-4,400 rpm at approximately 1-2 cycles per second. (3) At WOT surge stops but max rpm 3,900.
Change/Tested: (1) Throwing no codes at any time. (2) Run on portable tank with new fresh gas. (3) Plugs (twice). (4) Complete lp and hp fuel system check/disassmbly (hp pressure exactly on spec and rock solid through entire rpm range).
(5). Beginning to suspect MAP sensor. Checked voltage per service manual. At 0 kPa right on the money @ 4v. At 40 kPa also correct @ 2.4 v. But cannot get to 80 kPa with hand pump. And MAP sensor isolated will not hold vacuum. Takes 3-4 seconds to bleed off vacuum when pumping stops. Hose checks out fine - no leaks.
Question: Should MAP sensor hold vacuum? (Don't know the internal mechanics but acts like there could be a diaphram that has started to leak).
What else could be the problem?
