I have a 1989 Evinrude 88hp outboard motor vin # VE88MSLCER with the trim/tilt pump leaking. The pump is leaking from the o-ring but I cannot remove the ring for the life of me. I was able to remove two of the three nuts. The third nut is hidden behind the pump and is impossible to remove without removing the motor. I was wondering if I could disconnect either the wires or hose to make it manual just for the time being? Stripper season just started and I really dont want to lose out on the fishing. Any help will be extremely appreciated.
