have 1994 johnson 40hp. bot a complete water pump kit. going by a sealoc manual says to use adhesive sealant on the o-ring, driveshaft o-ring,housing grommet, sealing compound on gasket, and the four mounting bolts. guy behind counter at gone fishing marine says no sealants needed. if needed what adhesive sealant, sealing compound should i use? i'm presuming thread sealer,(not the permanent type) for the bolts. maybe marine silicone ffor the others?
thanks for any help....Bill
