Hello. This is a 91 5hp Gamefisher/Force engine. Gas flows out of the carb when I squeeze the bulb. Only thing that it could be was the needle and seat? I just put in a NEW needle/seat and the same thing happens. Then I realized when I squeeze the bulb...the gas is forced through the main jet inside the fuel bowl...up and out the mouth of the carb.
The couple times when I did get the damn thing started, it speeds up....then slows down...over and over. I adjusted the float according to the service manual.
I am dazed and confused with this. Sure would appreciate any knowledge out there.
Thanks!
Ski
Thanks!
Ski
