I screwed up and hooked the battery up backwards. I read that this would fry the regulator/rectifier The only thing is that this model that I have does not have a regulator/rectifier. It is a 2001 90 hp Evinrude Ficht engine. It feeds directly from the stator from what I am reading from the manual. It also will not start from the key switch but I can turn the key switch to on and jump across the solenoid and it will start. Does this indicate that the solenoid is bad? Did this fry the charging system in the stator? Any help is appreciated.
