- Jul 18, 2011
- 17,711
Hi Folks -
This weekend I was sanding the hull of my 'new-to-me' boat (Formula 33 foot) in order to get ready for painting of a Barrier coat and then an Anti-fouling paint.
The boat is currently on blocks and stands, the thing weighs approximately 9,000 lbs . . . So, there are 2 areas, fore and aft, where the hull rests much of its weight on the stack of blocks. See (click) image below
I have been able to move the 4 stands, that you see in the picture, around to sand underneath the pad areas, but the areas obstructed by the blocks (circled in picture), remain untouched.
The Question:
For those who have dealt with larger boats or similar heavy objects, I am wondering what techniques I might use to access, prep and paint the areas obstructed by the stack of blocks. Each area is about 1.5 square feet of hull. I figure that I could make another stack of block adjacent to the existing stack(s) . . . but transferring the load would still be quite a challenge, and one with a high penalty of failure
Any tricks of the trade or techniques that folks have used with good results . . . :help:
I DO need to prep and paint these areas as they will become barnacle paradise in about 3 weeks after launching, if I do not.
T.I.A. for your advise and comments.
The Question:
