Wonderfulfishing
- Mar 27, 2011
- 8
Have Johnson J200VXSSS. Ran fine last year. I started it few days ago fired right up. Changed plugs. Ran idle for 1/2 hr. Put the boat in water and it ran fine for 5 miles. There my problem started. The engine stated shutting on low rpm. Sounded like not all cylendars are firing. Kind of less power. I pushed the throttle all the way and the tried again to start; it started running with kind of half power and coughing. I quickly engaged the gear and pushed the throttle again. It ran for few miles but still shuts down on low rpms. Last few miles I switched to 9.9hp mercury kicker (4stroke) and came to the docks at 5mph on kicker. The kicker ran fine on same fuel line.
Any ideas? I am split on changing the fuel or changing the ignition coil. What else could be wrong?
