Having some starting issues I was looking at addressing before getting onto the lake this year. I bought this boat at the end of the last season, and have found that it does not like to start at all. This is my first boat, and while I am not new to engines, I am certainly inexperienced with these older 2 strokes.
I did a compression test on this motor, the results seemed to be good, they were all within 5% at around 110 psi. This may be a little low from what I have heard, but all cylinders are at least consistent. The spark plugs are brand new, they are the correct ones and are gapped, and the coils look to be in okay shape. Once it is started, though it seems to lack a bit of power, it runs smooth from idle all the way through to WOT.
For the cold starting procedure, I use full choke, and pump the primer bulb until it is quite firm. No matter how long you crank the motor, it will not start. It also does not start if you "pump" the throttle when cranking. (old farmers' trick Ive heard works on some older motors). Eventually I give up, and remove the intake cover, and spray my bottle of premix into the carb. Depending on the day, it will either need just a little bit of this extra "liquid encouragement" to get started, or it will seem to depend on my premix bottle to run for a bit, then catch.
Further, the motor seems to take a long time to "warm up" (it will stall if gear is engaged and any sort of throttle is applied, no matter how gentle if it is not fully warm)
Finally, once the motor is shut off for fishing, etc, once you attempt to restart it, it will start right away on the first key, but if it doesn't catch (maybe 1 out of 5 times this happens) then it will rarely catch on any successive attempts, and I have to go back and remove the motor cover, intake cover, and get out the premix again.
I am just wondering what I should be looking at first, whether it be a fuel pump, carb rebuild kit, etc?
Thank you for reading my novel, and any help is appreciated!
Evan
Evan
