  #1
Old April 6th, 2005, 12:09 PM
bayman bayman is offline
Default Building small pontoon boat
I'm starting work on a 10 foot, 2 person pontoon boat. This will be the third boat I've owned but I've never owned a pontoon boat. I'm wondering what accessories and features everyone likes on their (small) pontoon boats. What recommendations do you have? I plan on using it for exploring, cruising around lakes, and fishing.
  #2
Old April 6th, 2005, 09:30 PM
beniam beniam is offline
Default Re: Building small pontoon boat
baymanAlways liked enterprising projects.Just wondering out loud; 10ft long, one foot diameter (round at .78 sf), 2 pontoons....thats 15 cf. Times 62.4 # per cubic foot,say at one half under water..468 pounds carrying capacity. Not a lot. Just a guess and a thought. Be happy, enjoy life and be safe. Batavier
  #3
Old April 6th, 2005, 09:40 PM
Dunaruna's Avatar
Dunaruna Dunaruna is offline
Send a message via Skype™ to Dunaruna
You'll need 16" diameter minimum.Not much room to add features but here's my list: BBQ, ice chest (under a seat/bench?) and a landing board, a 12" wide board that slides underneath.Aldo
__________________
Watch this space......................
  #4
Old April 7th, 2005, 06:16 AM
16 inch diameter, 10 ft long...half deep in water,say 1100 pounds.Your deck will be 8 inch plus stringers and floorboard..say 12 inch above water.Sounds like a fun project. Enjoy life, be happy. Batavier
  #5
Old April 7th, 2005, 09:27 AM
Thanks for the ideas and thoughts everyone!I have started on the pontoons. They are 18" in diameter and all the way to the outside. The deck will be lower than the top of the pontoons so that it isn't too high above the water.The landing board - does this function as a step when beaching? I'm not familiar with the term.
  #6
Old April 7th, 2005, 09:53 AM
Any recommendations on horsepower?
  #7
Old April 7th, 2005, 01:35 PM
Bond-o's Avatar
Bond-o Bond-o is offline
Master Shipwright
An Eletric Trolling Motor ??
__________________
Any Grease is Better,..... Than No Grease at All.......
NO PM's (Private Messages) regarding boat/engine problems. That is what these forums are for.
They will be Deleted
  #8
Old April 7th, 2005, 02:48 PM
Would a 9.9 hp engine be sufficient?
  #9
Old April 7th, 2005, 03:14 PM
AMD Rules's Avatar
AMD Rules AMD Rules is offline
Grandfather used to have a home-built pontoon style boat...called "Huff 'n Puff".It was powered by human effort..... both passengers peddling away to spin a single prop (via chain, sprockets, etc.) All Good excercise, and environmentally friendly. An great fishing platform.
__________________
'72 Glastron GT160 c/w '72, '84 and '86 Merc 115hp
'67 Merc 3.9hp , '70 Merc 9.8hp, '61 Merc 50hp ... The Merc Nut
  #10
Old April 7th, 2005, 03:15 PM
Dunaruna's Avatar
Quote:
Originally posted by bayman: The landing board - does this function as a step when beaching? I'm not familiar with the term.
It sure does. When beaching, you don't have to run up the bank, just gently touch the bottom and then extend the board. The marina I am in supply 10ft toon boats as tenders, they all run 6hp. 9.9hp is ample.Aldo
__________________
  #11
Old April 7th, 2005, 03:47 PM
I wonder if most pontoon boats in the US come with a landing board. It sounds like a good idea but I want to see how some of them make them. I've seen plenty of pontoon boats around but I have never noticed this feature. It seems that it would be similar to a kitchen cutting board that just extends out when you need it.
  #12
Old April 7th, 2005, 03:52 PM
Dunaruna's Avatar
I've got one, granted it's on a 45ft houseboat but it doesn't matter what size your building, the principle is the same. I'll post a pic if you want.Aldo
__________________
  #13
Old April 8th, 2005, 09:18 AM
A pic would be great, thanks Dunaruna!
  #14
Old April 8th, 2005, 10:18 AM
Realgun Realgun is offline
Whre I come form its called a plank and you dont't want to walk it. ! ArgeThat a great idea though. To bad my bowrider is so high in front makes it hard to get on when beached.
  #15
Old April 8th, 2005, 12:02 PM
Hey Realgun, for larger boats, are ladders like this any good? I've seen them but haven't ever used one.
  #16
Old April 8th, 2005, 05:32 PM
That looks insteresting but how does it work? I have never seen 1 before. My boat when landed seems higher than it should be but I can get in an out it just seems higher than the old boat we had as a kid.!
  #17
Old April 11th, 2005, 05:46 PM
Here is the description of the that bow ladder:Mounts to deck or side of any boat. Angled entry creates Stowaway - Stairway for easy exit from beach or boat. Folds flat when not in use. Lightweight, easily removed for stowage. Hi-tensile anodized aluminum and stainless steel construction. Includes stainless steel mounting brackets, quick release pins and nylon lift strap. 300 pound capacity. http://www.iboats.com/mall/index.cgi?prod_id=40550
  #18
Old April 13th, 2005, 03:50 PM
Dunaruna's Avatar
Sorry Bayman, I thought I had a picture but I can't find it. I'll take one the next time I go up to the lake but that may not be for a few weeks.Aldo
__________________
  #19
Old April 14th, 2005, 10:08 AM
Actually, a few weeks from now would be perfect since I won't get to that part of the boat for awhile. I'm still messing with what little features I want to build into the fiberglass - such as hand hold grips and so forth.
  #20
Old May 2nd, 2005, 05:19 PM
Dunaruna's Avatar
Bayman, here are the pics as promised.This has been way over engineered because we also use it as a diving platform, all you really need is a plank that slides in and out of 'C' channel. pic 1 pic 2 pic 3 pic 4 pic 5 pic 6 Aldo
__________________
  #21
Old May 2nd, 2005, 06:41 PM
Thats a neat Idea you should patent it.
  #22
Old May 2nd, 2005, 06:42 PM
Bayman how are you doing on that small toon?
  #23
Old May 2nd, 2005, 06:56 PM
Dunaruna's Avatar
Realgun, are you suggesting that houseboats in the U.S. don't have these? I built this myself but to be honest, I copied the design from another houseboat. His was remotely operated (little starter motor type setup, I believe it was actually a wheelchair motor), mine is manual. Are you interested in becoming the northern hemisphere distrubutor? Aldo
__________________
  #24
Old June 27th, 2005, 03:22 PM
Wow Dunaruna, that is a pretty cool setup! I haven't seen anything like this either. It does look to be engineered very well. I got delayed a bit there but I'm back at work on the little pontoon. The current plan is that it will only be barely over 11 feet long or about 3.4 meters.Hooking up some small motors might be cool though. I don't know if I could do that on this little craft or not. Other than the engine, everything will be manually operated at the outset.
  #25
Old July 2nd, 2005, 09:07 PM
Mike Johnson Mike Johnson is offline
for very interesting small pontoon boats contact Harry Wells dba FloridaCraft Stewart, Florida
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Building Pontoon Floor.... bherron Boat Restoration and Building 12 January 30th, 2007 05:14 PM
building a hardtop for a pontoon flashback Boat Restoration and Building 7 October 9th, 2006 09:31 PM
building Aluminium pontoon Rigby Boat Restoration and Building 13 November 11th, 2004 05:44 PM
25 HP Yamaha for small pontoon boat jrj101 Non-Repair Outboard Discussions 4 August 15th, 2003 06:19 PM
Building a small mold, looking for advise MarlinTini Boat Restoration and Building 5 March 14th, 2003 02:50 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
