Abomb27
- Jan 6, 2013
- 141
Hi, I am going to be taking my OMC 115 turbojet out if my boat and attempting a rebuild. I have low compression on one cylinder 60 psi the other 3 are all 90 psi. I pulled the heads sent them to a machine shop and replaced head gaskets. Still 60psi on one and 110 psi on other 3. Gonna run OMC power tune through motor too see if it helps. if not gonna pull the motor and have block sent to Machine to either be honed or bored. I am replacing the rings, gaskets, will inspect and replace pistons if necessary. My question is what else should I be concerned of replacing while I have it apart. I capped this rebuild @ $700 anymore and I think it would be better to get a new motor.
