Re: Trailer Tongue Weight
Boat trailer manufacture require 5-7% on a tandem BOAT trailer, when other trailers want 10% or more.
I talked (phone) to Jerry Townsend several years ago and one of the questions was about why a tandem boat trailer was only 5-7%. and a camper, utility, etc. were +10%. The short of it, was there is no advantage going higher for a tandem boat trailer.
I asked the same question to the owner of
Boat Trailers, Boatwheels, Custom Aluminum Boat Trailers . Yep, same, no advantage. 5% is what most customers ask for and he has no problem with it.
I'm setup for about 6%, 400lbs. empty (fuel not in consideration), loaded I'm under 7% 500lbs. The truck and trailer are level empty and never more than 1" drop at the hitch loaded. For my peace of mind, this is perfect, turnpike speeds, rain, panic stops, even on snow covered roads it handles great.
My original setup was 12% 800lbs and ran it for years, but was just never right. So a phone call to Jerry and a little face to face at Boatwheels with the trailer, and decided to believe the experts and make a move. If it works I'm good, if not then I could always go back, no biggie.
I did the math (thanks Jerry) marked the trailer and moved the axles one time. The move took less than hour from start to finish. The results were as stated above, perfect for 5-6 years now.
Every setup is different, and to go against everything I'd done in the past on trailer setups was hard.
I guess sometimes it's just hard to believe the boys that design and build something are right. :facepalm:
Looks/sounds like the boat itself is good on the trailer. Transom beyond the trailer and the bunks beyond the transom is common. So just move the axles to your manufacture's specifications.
It's just not that hard to move the axles.
huts
Classic Whaler: Boston Whaler: Reference: Trailering: Calculations
